need pump help
Old Sep 10, 2010 | 08:24 AM
aarons12v's Avatar
Default need pump help
i have a 92 ve pump that i just put a bd governor spring and fuel pin in. the problem now is that when you are at about 1/4 throttle the rpm just spikes to 3/4 or full throttle. when you release the throttle it will return right away. is this normal or did i screw something up.it makes it a bear to drive in town. sorry if i sound stupid i just starting to learn about this pump. thank for your help.
Old Sep 10, 2010 | 11:41 AM
JBradley500's Avatar
you might want to take apart the linkages and springs that are on the pumps throttle shaft... you may have the large plastic and small metal washer binding up.
Old Sep 10, 2010 | 12:40 PM
aarons12v's Avatar
the linkage is free. is the pin that rides on the fuel pin supposed to move free cause mine is a little stiff.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Renteria1217
Apr 16, 2015 11:38 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
