Conversion question
Old Sep 10, 2010 | 02:37 PM
bcmopar's Avatar
Default Conversion question
Hello all,,, have 93 club 4x4 that has was original 5spd that PO converted to 47rh my question is i'm using toggles to control od and lock up but is there something i'm missing when I come to a stop it's like i'm in 3rd and it almost dies is there something from TV cable?? sorry for long first post
Also but when I take off it goes up through gears as normal
Anyone??
Old Sep 10, 2010 | 02:42 PM
Mark Nixon's Avatar
Ever tried to unlock the convertor and shut off the O/D, BEFORE you stop?
Both can still be active at 20mph, since they aren't computer controlled with the toggles.
Mark.
Old Sep 10, 2010 | 05:16 PM
bcmopar's Avatar
yeah both are off when stopping.
Old Sep 11, 2010 | 11:42 AM
Mark Nixon's Avatar
Adjust the TV cable per the FSM manual for '93.
Also, make sure that the TV cable moves freely.
Mark.
Old Sep 11, 2010 | 07:49 PM
bcmopar's Avatar
any help on adjustments?
Old Sep 11, 2010 | 10:24 PM
tltruckparts's Avatar
Mark.
considering its got a 47rh in it the tv cable may be adjusted for a 93 whihc oculd be causing the gears to shift funny. i would get it adjusted more along the lines on a 94-98 truck. (they might have the same adjustment though i dont know for sure)
Old Sep 15, 2010 | 04:06 PM
Mark Nixon's Avatar
I usually set them with a 3/16 drill bit, or bolt, between TV "peg" and the cable REAR of the slotted end, set so that it's tight to the bit.
One other thing.
Before you go to all this trouble, make 100% sure you have full throttle travel at the pedal by having someone push the pedal to the floor so you can verify that the pump and K/D linkage peg is at full travel.
Adjust the pump linkages accordingly.
If you adjust the TV cable without verifying full travel, it may well still function the same, because you don't have proper full pedal operation.
Also as I mentioned in an above post, make SURE the TV cable is not binding in a partly released position.
Lube it well from boths ends.
They tend to work stiff, because they are hardly ever maintained.
Mark.
Old Sep 15, 2010 | 08:39 PM
bcmopar's Avatar
Full throttle good cable moves good @ both ends just seems like when you come to stop with 5spd in higher gear and don't have clutch in?
Old Sep 15, 2010 | 09:45 PM
Mark Nixon's Avatar
Still sounds like the convertor is not unlocking.
Mark.
Old Sep 15, 2010 | 10:08 PM
bcmopar's Avatar
Hmmmm both switches appear to be working can feel both shifts.
