01 cummins auto tranny issue
Old Sep 9, 2010 | 06:17 PM
DobermanDiesels's Avatar
Default 01 cummins auto tranny issue
ok so my 01 cummins started something wierd today so i had a feeling it was the ouput sensor on the tranny since it has done this before very similar anyway, so i put it in and it did not change, the truck is not shifting form first to second but once it gets second it shifts normal or great infact i can get it to change if i manually move the colum from 2nd to drive but its hit and miss im gonna try to adjust the tv cable but like i said it changes perfect from 2nd on and down shifts fine it just hangs in first any ideas? no codes no nothing just hanging in first
Old Sep 9, 2010 | 07:22 PM
oudive's Avatar
Sup,
Maybe look into the last time the bands were adjusted maybe, fluid and filter change? Just throwing that out there. I know when I first adjusted mine I over adjusted and it would not shift out of first. Hope it helps, good luck with it they can be frustrating.
oudive
Old Sep 9, 2010 | 07:31 PM
i changed fluid and had bands adjusted about 6 months ago i think i have over adjusted its dark here now but i tried messing with tv cable i have never had to do that and i am looking into how to do it the best what gets me is that i can put the colum in 2nd and shift it to drive and its perfect like all the rest of my gears are perfect downshifts and all i am leaning toward it being the cable it seems like alot of pople on this forum have had trouble with the first to second shifting problem? anymore ideas
Old Sep 12, 2010 | 09:32 PM
mb5n537's Avatar
mine was doing the same thing not wanting to shift from first to second unless i let out of it, i adjusted the cable and it helped alot, didnt fix it completely but helped, gonna try to adjust some more to see if it helps, if you get yours fixed let me know how you did it, its irratating as crap
Old Sep 13, 2010 | 08:04 AM
i replaced the solenoid and gov pressure transducer and adjusted the tv cable to exact specs and its like i have a new truck it has never shifted so perfect the parts where 126.00 plus new filter and trans fluid and its the best money i have spend in along time
Old Sep 13, 2010 | 08:47 AM
turbo20psi's Avatar
I have installed this kit on several trucks and it has worked great the solenoid does not get clogged up with debris from the bands.
"RE" HD Master Electrical Kit 00 Up
Old Sep 14, 2010 | 10:54 PM
T-MAN's Avatar
My 02 just started not shifting at all reverse is great low gear great also, just will not up-shift; replaced the governor pressure solenoid and the pressure transducer still wont (bad word) shift.
how do I adjusted the tv cable....specs please
Old Sep 15, 2010 | 08:34 AM
turbo20psi's Avatar
http://www.dieselbookmarks.com/bombe...Adjustment.pdf
JoeyMiR
9
Feb 3, 2018 10:05 PM
85IDI_International
Apr 24, 2015 01:08 AM
trab123
Feb 9, 2015 09:44 AM
Nov 4, 2014 08:10 AM
Oct 28, 2014 08:10 AM
