code dodge
Old Sep 9, 2010 | 05:07 PM
dodgedad's Avatar
Default code dodge
have a code that says tach circuit low voltage. what could this bep1693
Old Sep 9, 2010 | 05:25 PM
Whats the actual error code number?
Old Sep 9, 2010 | 05:52 PM
mishkaya's Avatar
Yep, actual code # would be most helpful.
Old Sep 9, 2010 | 06:29 PM
jake 94's Avatar
He said above its a p1693
Old Sep 9, 2010 | 06:34 PM
mishkaya's Avatar
It wasn't there earlier...
To the OP: P1693 is simply a companion code on our trucks, it means that another DTC was set in either the ECM or PCM. By itself, it means nothing.
Old Sep 9, 2010 | 06:36 PM
RAW's Avatar
RAW
Yep, delete it and move on.
Old Sep 9, 2010 | 06:47 PM
No use a scanner on it to see if there is another code stored.
And no that code wasnt there before.
Old Sep 12, 2010 | 07:44 AM
vectorboy_99's Avatar
I got this same code, and the truck has intermittent surging problems. So this code just means there is another code somewhere? Why isn't it giving me the second code then? I used the key on-off method to retrieve the code. So how do I reset?
Old Sep 12, 2010 | 08:54 AM
mishkaya's Avatar
You need a code scanner to retrieve the other code, and also to reset the codes. The odometer display does not show much, but it is still better than nothing...
Old Sep 12, 2010 | 10:36 AM
I did find out on here that, using the key on-off method, you have to wait for the second set of codes. It says done after the first code, then gives you the second code after that. Just have to watch until the odometer reading comes back on. Try that and see what you get. Mine came back with a p1689 which is a fault from the electronics on the pump to the ecm. So now i need a new pump sucks. My wife just handed me a stack of bills she is not paying and moved out. NICE week. Maybe I will get hit by a comet now. Sorry for venting this just could not have happen at a worse time.
Jim
