Hola, new diesel user aboard!
Old Sep 9, 2010 | 04:45 PM
DieselRamcharger90's Avatar
Default Hola, new diesel user aboard!
Hey guys, Ive got a few questions for ya'll. Well lemme start off by saying you guys are all very knowledgeable peopl and really know your trucks! And thus why I'm now a member. But anywhoo, I have a highly customized '90 Ramcharger that we put a '92 cummins in! It's a beast! 4x4, 4.10's on 37's with teflon wheels, no rust! stock w250 lift up front and a 5" in the back to get her even. Putting in the 3200 GSK 2moro, Denny T when it arrives in the mail, star wheel and smoke pin all the way down, and looking for injectors. So A. What's the best way to tell which turbo I have on there? Is there an imprint or easy measurement? I know a lot about my motor except that one fact. call me dumb.. and also with the bigger fuel pin and 3200 GSk, how important is it for me to get the bigger injectors? And if i go bigger, how big? and when will i need a bigger lift pump with said injectors? Sometimes I feel lost. also If i decide to go with a 16 or WGT'd 14 then what should I go with and what's the best comp/turbo combo? any info would help!
Old Sep 10, 2010 | 11:48 AM
JBradley500's Avatar
youll have an h1c... the larger of the 2 h1c's but its still a relatively small turbo. i wouldnt get injectors until you have a better lift pump... as soon as you have those 2 youll want a turbo... as soon as you have that youll NEED a clutch or built auto, depending on what transmission you have.
you need to read about the "power screw/fuel screw"... that will give you some pep. also read about runaway and fuel shut down solenoid before you mess with the power screw.
Old Sep 10, 2010 | 02:48 PM
Lol I figured as much. Whats the recommended "next step" fuel pump? I have a south bend so my clutch is good to go. Ok, thanks a lot man. And I have both my star wheel and smoke screw tightened all the way down flush (Powered up) are u talking about another screw?
Old Sep 10, 2010 | 04:27 PM
yep... power screw is the big daddy of the screws on the VE pump... youre going to want to move the smoke screw back up if you mess with the power screw... youll really make smoke when the power screw is turned.
read this
http://www.dieseltruckresource.com/d....html?t=158962
then heres something that has power/fuel screw written in there.
Turning up the pre 94 Ram diesel injector pump
the next step fuel pump would be a piston pump for mechanical or an airdog/fass/walbro if you want electrical. piston pumps come in low pressure and high pressure. you need to regulate the high pressure but it puts out lots of fuel even when you start making lots of power.
Last edited by JBradley500; Sep 10, 2010 at 04:28 PM. Reason: Automerged Doublepost
Old Sep 14, 2010 | 03:27 PM
Thanks for all the help you guys. now i need 10 posts so i can answer pms!
Old Sep 14, 2010 | 03:44 PM
tiremann9669's Avatar
Make sure you have a pyro guage
Old Sep 14, 2010 | 08:30 PM
geddy's uncle's Avatar
I think I've seen that truck.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 6, 2015 03:20 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
