NV4500 Swap
Old Sep 8, 2010 | 02:27 PM
cumminsCrazy's Avatar
Default NV4500 Swap
just wondering will my pcm and wire harness work for the standard trans when i swap or do i need a harness for a standard ?
Old Sep 8, 2010 | 03:56 PM
cummins95's Avatar
yeah it'll work. u need to cut n splice some wires in order to make ur clutch safety switch n reverse lights work.
Old Sep 8, 2010 | 04:00 PM
cool and 94 truck stuff will fit a 97? im trading a friend
Old Sep 8, 2010 | 04:12 PM
cummins95's Avatar
yep it'll all bolt right up
the trans in my 95 is out of a 96. you wont regret the swap, its a completely different truck now
Old Sep 8, 2010 | 09:20 PM
awesome im sick of that dang auto it just causes stress
are the trans adapter plates the same or different
Last edited by cumminsCrazy; Sep 8, 2010 at 09:20 PM. Reason: Automerged Doublepost
Old Sep 9, 2010 | 06:45 PM
cummins95's Avatar
the bellhousing will bolt right up. you'll need the transfer case from the manual cuz the input shafts are different. you'll also need both driveshafts cuz the standard is alot shorter than the auto. but if you get a donor truck you'll have everything u need. its an easy swap
Old Sep 9, 2010 | 10:49 PM
ya how much do i need to lengthen my drive line cause the truck im getting the parts from is a single cab and i have a xtra cab he is giving me the slip joint that fits the transfer case
Old Sep 10, 2010 | 09:55 AM
96blackcloud's Avatar
i did a write up on this swap a while back. the entire manual assembly including transfercase was only a inch shorter then the 47re with t case. i was able to use my stock rear drive shaft and i replace the front drive shaft with a shorter one. as for ur wiring look up my conversion write up it explains how to do everything.
Jonrarick
Oct 25, 2016 01:32 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
DuramaxBen
Feb 6, 2015 10:32 AM
CumminsMan2.0
Dec 11, 2014 04:57 AM
Jgloveracob
Nov 16, 2014 07:27 AM
