No start, no start. Ok, it started.
Old Sep 8, 2010 | 01:48 PM
Nitelord's Avatar
Default No start, no start. Ok, it started.
Within the last two weeks, my truck has started giving my some attitude.
I go out and jump in. (doesn't matter what time or even if it's already warm.)
Turn the key, nothing, but a relay click. turn it off, turn it on, - nothing but a click.
7th time, she starts. I go to work, gas station, Wawa, where ever. Shut it off, go to leave and I get the same stubborn attitude. Sometimes it takes 3 taps from the key. Maybe 7. As many as 14, once.
Any ideas as to where to start? I was under the impression, if it was the starter, she would be dead always. Yes or no...
Thanks in advance!
Old Sep 8, 2010 | 02:56 PM
wildbill's Avatar
Not necessarily. Have you tried cleaning all the terminals, load testing the batteries, having the alternator checked out??
Old Sep 8, 2010 | 02:58 PM
Nitelord's Avatar
I cleaned the battery terminals and checked the grounds I could find. Two new batteries as of November 2009. I have not checked the alternator. Will do that tonight if I get home before dark. thx.
Old Sep 8, 2010 | 03:05 PM
wildbill's Avatar
Parts stored can do the test for free. If all checks out, then go ahead and remove the starter and have it tested.
Old Sep 8, 2010 | 03:21 PM
24vcumminscowboy's Avatar
i bet its ur starter contacts google larry b's starter contacts
Old Sep 8, 2010 | 04:06 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
starter contacts. one of them will be wore down.
Old Sep 8, 2010 | 04:25 PM
Nitelord's Avatar
I really like the Larry B's. I may just get the new starter and super contacts. Just do the whole thing and be done. I'll see what the parts store says.
My mechanic had a death in the family and is out the rest of a week and some days.
Thanks again. Any more suggestions, I'm all ears. I'll get the alt. and starter checked out in the next couple of days.
Old Sep 8, 2010 | 04:50 PM
PLMCRZY's Avatar
Ill put my money on your starter i had the same problem. I just replaced the whole starter for $150 but i got a lifetime warrenty on it
Old Sep 8, 2010 | 05:29 PM
mishkaya's Avatar
If you still have the OEM starter, keep it and do the starter contacts from Larry B. I doubt anything else is wrong with your starter, but you might end up with endless headaches with a reman (forget the price of a new one). My .02
It's a job you can relatively easily do yourself. All you need is a 12 point 10mm wrench (or whatever size it is) and a lot of strength. There are only three bolts holding it in...
I have done the starter contact swap on four trucks already and can usually get the whole R&R thing done in less than an hour.
Old Sep 9, 2010 | 12:37 PM
moparious maximus's Avatar
Contacts in the starter for sure.
You can replace them for dirt cheap or even upgrade to better ones.
I bet its only one contact, the one on the battery side it always dies first, the plunger ring thing and the starter lead contact usually look good.
