Guages
Old Sep 8, 2010 | 10:32 AM
DanS's Avatar
Default Guages
I have a fairly stock 2007 2500... its got deletes and smarty and may have larger stuff coming soon. I wanted to get some gauges before I did anything else. I'm not sure which gauges to get or how many to get to plan for the future. I mean EGT and rail pressure I suppose are a must, boost pressure would be nice, what else would anyone suggest? What are the installation housing options inside the truck? What are some good brands, I'm really trying to get a better idea here.
Old Sep 8, 2010 | 11:07 AM
Farmboy 2.0's Avatar
Does it have an auto? If it does get a trans temp, boost, pyro. IMO you only need a rail pressure gauge if you are highly modded. For that year of truck i really like the Autometer Phantom 2's. They have the option of green back light and are whitefaced to almost match the factory gauges
Old Sep 8, 2010 | 08:53 PM
300ft.'s Avatar
if its an auto i suggest a four guage pod with boost, pyro, tranny temp, and fuel pressure( lift pump supply pressure) as long as you have more than 8 or 9 lbs under a hard load, your rail pressure will be where it needs to be.
Old Sep 8, 2010 | 08:58 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
we sell autometer and isspro.
Old Sep 9, 2010 | 09:14 AM
barkrulz's Avatar
gotta love the Maxxes they have all the gages built in except fuel pressures.
Old Dec 1, 2010 | 05:15 PM
beerlvr's Avatar
how does the isspro tranny temp hook up do you have to drill a hole in the pan for the sensor?
Old Dec 2, 2010 | 03:51 PM
cumminscontrol's Avatar
i wouldnt put it in the pan, u run the risk of ripping it out ...put it up on the side so it dont hang down low...just my .02 worth
Old Dec 2, 2010 | 04:31 PM
crzycummins's Avatar
probably the most accurate reading will be in the pan but there is probably a unused port in there somewhere
Old Dec 2, 2010 | 05:02 PM
beerlvr's Avatar
i found a kit at diesel manor that splices into the cooling line should work just ain't too excited about cutting the line
casper83
Jun 5, 2015 04:35 PM
KEG
Price Quote - Request A Price
Mar 30, 2015 09:23 AM
VonSchmidty
Feb 28, 2015 09:32 PM
StreetRat
Jan 13, 2015 05:05 PM
