Fuel Pressure Gauge Install
Ok guys, I just bought a GlowShift FP gauge for now just to cover my 6 until I can get a little more money for a complete set. But anyways, all I received from GlowShift was the sending unit, the gauge and the wiring harness that connects to the rear of the gauge wires are only about 12 in. long. What else do I need to make this install happen today?
Get a tapped banjo bolt and install on the outlet of the fuel filter housing (on the bottom). Mount the sender on the fender and connect the two with a grease gun hose (1/8" npt thread), run your wire through the firewall to the guage.
this is for an 02 with a raptor still correct?
Last edited by silverstreak02; Sep 8, 2010 at 12:53 PM. Reason: Automerged Doublepost
Alternately, you could install the grease gun hose on the test port right on the VP-44 but I wouldnt recommend doing that. The test port is a test port and you should leave it free for that reason. JMO of course.
To install it on the test port it would look something like this (again minus the needle valve):
Hope that helps.
RatsMC
May 4, 2015 05:25 PM
scottxmorris
Oct 8, 2014 02:14 PM
