Brakes
Old Sep 8, 2010 | 01:12 AM
94cummins diesel's Avatar
Default Brakes
got a 94 cummins having some brake issues when i put my foot on the brake it doesnt stop well,but i noticed my brake lights on could i need to add fluid or maybe re bleed them let me no maybe im due for new pads thanks for the help -pat
Old Sep 8, 2010 | 01:42 AM
tiremann9669's Avatar
If the light is on you're probably low on fluid, and if thats the case you probably have a leak. So for starters I would make sure it's full and any leaks are fixed. Then you'll get a better idea if you need brake pads
Old Sep 8, 2010 | 01:45 AM
Default brakes
ok,well the truck sat for a while b4 i bought it u think i should do new lines an add new fluid,what should i use for fluid new at the whole diesel world thanks for your help
Old Sep 8, 2010 | 06:59 AM
dot3 fluid will be fine.
Its probably time for a complete inspection and overhaul. You can also swap in wheel cylinders from a chev 1 ton in the rear. These will really help increase the braking power of your rear drums. Should be able to find the p/n with a quick search.
Old Sep 9, 2010 | 04:29 AM
Default brakes
ok thank you
ok i checked the fluid it is fine right up to the full line,u think i should try an bleed them then drain the system an put in new brake fluid?or could it be a broken line anything will do
Last edited by 94cummins diesel; Sep 9, 2010 at 04:29 AM. Reason: Automerged Doublepost
DC_DC41
Jul 16, 2015 09:56 PM
Radioking1777
Jun 9, 2015 04:13 AM
Jun 8, 2015 07:10 AM
thatdude38
May 9, 2015 12:21 PM
kryz9903
May 4, 2015 05:00 AM
