94' 7.3 idi turbo
Old Sep 7, 2010 | 01:31 PM
Sandman8105's Avatar
Default 94' 7.3 idi turbo
I am having problems getting the truck to bust off without pumping the gas. I just bought it from the second owner. He already told me that one of the injectors needs new o-rings. Could this be causing the problem? Only thing that baffles me is it acts like it is getting air in the system ant the fuel filter is a brand new wix filter. Any help solving this problem is greatly appreciated.
Old Sep 7, 2010 | 02:42 PM
DieselCrawler's Avatar
if the return line orings are leaking air intrustion will occur and hard starting will be present. get a fuel line return kit and install.
Old Sep 7, 2010 | 05:43 PM
Thanks Crawler. I may need a little more help from you later with this old girl.
Old Sep 7, 2010 | 06:33 PM
ask away.
Old Sep 7, 2010 | 08:39 PM
Well, the starter positive was loose and so was the battery positive. She started up from there with a little shot of ether. Now just wondering if part of the fuel problem was due to the voltage and the filter water drain not being closed and sucking some air. I still need to change the o-rings on that one injector. I really need to use my head a little more and brush up on my diesel mechanics.
Also, what is the pan directly below the torque converter with the open ended nipple sticking out of it?
Last edited by Sandman8105; Sep 7, 2010 at 08:39 PM. Reason: Automerged Doublepost
Old Sep 7, 2010 | 11:27 PM
pic? not sure what u are talking about cept for the torque converter access panel.
Old Sep 8, 2010 | 11:12 AM
I don't have a pic. All that I can tell you it that it is about a foot long with an open end nipple sticking straight out toward the rear. I figured that it might be some kind of over flow drain or something. But, it is directly below the torque converter.
Old Sep 8, 2010 | 11:46 AM
cowboyford16's Avatar
I think you are meaning the dust cover.
Old Sep 8, 2010 | 12:10 PM
Could be, but it looks like a little oil coming out of that nipple.
Old Sep 8, 2010 | 01:23 PM
They all have oil coming out of it, its no big deal. It leaks from the rear main seal
