01 GMC Duramax LB7 LOSS of Prime
Old Sep 7, 2010 | 11:31 AM
LDABLO's Avatar
Default 01 GMC Duramax LB7 LOSS of Prime
I have a 2001 GMC 2500HD with a 6.6L (LB7) I keep having problems everymorning when i start up. I'm loosing the prime or so it seems. Once I prime the system she runs and loabes at Idle and taking of once shes running everything is great. Any Ideas?
Old Sep 7, 2010 | 06:07 PM
2500HeavyDuty's Avatar
have you done any filter changes recently?
Old Sep 8, 2010 | 12:36 AM
LDABLO's Avatar
No I have not done anything since I got it from a Joe at Ft Richardson. I've had the truck for about 3 weeks it was woking good until it sat for 2 days and then I could not get it to start. my buddy and I check it and finally primed the pump at the fuel water seperator and she fired right up. I tried to listen to the pump at the tank but I hear nothing ( is there a pump in the tank?) I keep hearing yes and no from a bunch of people and the sad thig here in alaska I can't find a repair manual for my truck.
Old Sep 8, 2010 | 03:45 AM
duramaxfarmboy's Avatar
maked sure ur fuel filter and fuel water seperator screw are tight
Old Sep 11, 2010 | 03:28 PM
IH340Greg's Avatar
no there is no pump in the tank
Old Sep 16, 2010 | 12:04 PM
tfunk22008's Avatar
pump is located after filter there is a check port on your engine near the front right side were you can plug in a vacuum guage and if it pulls more that a couple inches of vacuum guage then its time to change the filter
Old Sep 26, 2010 | 09:03 PM
acdc's Avatar
there is talk about deteriorating rubber fuel hoses. start replacing them. and some of the rubber hoses are even collapsing inside. starving engine of fuel.
Sep 7, 2015 07:30 AM
Bamafantrey
Aug 24, 2015 09:30 AM
duramaxtuner
Diesel Engine Conversions
17
Jun 1, 2015 10:41 AM
Oleoleson
Mar 28, 2015 06:20 PM
gonza
Nov 17, 2014 03:51 PM
