60lb valve springs install
Old Sep 7, 2010 | 12:39 AM
posmx's Avatar
Default 60lb valve springs install
is this something i can do myself or am i better off with a shop? if i can anyone have directions? thanks
Old Sep 7, 2010 | 01:04 AM
jrad989's Avatar
valve spring compressor and some patience on the back ones. you can do it!
Old Sep 7, 2010 | 01:45 AM
big bad diesel 416's Avatar
Site Sponsor
its cake man put the hole you wish to work on on TDC (you can tell because the rockers will be loose) go get a spring compressor and bam your done oh and DONT drop the retainers use a good magnet if they go down the pushrod holes or into the cylinder you got a tone of work now
Old Sep 7, 2010 | 09:24 PM
cummins95's Avatar
do u have to pull the head to do it?
Old Sep 7, 2010 | 09:44 PM
Site Sponsor
Default Re: 60lb valve springs install
Nope
Sent from my DROIDX using Tapatalk
Old Sep 7, 2010 | 09:59 PM
94 12valve's Avatar
just take you time and make sure the retainer is in before you let the compression off the spring ... if not you will be looking for the retainer after you send it flying
RA113024
Mar 13, 2016 07:42 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
POWERSTROKEMANIAC
Dec 30, 2014 11:32 AM
twinturbo12v
10
Dec 8, 2014 07:58 PM
