reasonable amount of labor to pay?
Old Sep 6, 2010 | 08:14 PM
co84rc's Avatar
Default reasonable amount of labor to pay?
whats a reasonable amount of labor to pay to replace a p7100 pump?
Old Sep 6, 2010 | 09:47 PM
tltruckparts's Avatar
i dont know what i would call reasonable but i know the dealerships charge around 1000 bucks to install one for labor only and they wont even let you supply the pump either. i dont know why labor is so high though ive pulled on and off numerous times and ive had it off and back on within a half hour with my brothers help. but i would say if your payin on the side 2-300 is probably a reasonable amount
Old Sep 8, 2010 | 07:45 PM
Heavy Smoker's Avatar
You might as well DIY, but try rebuilding it rather than replacing it.
Old Sep 8, 2010 | 08:28 PM
co84rc's Avatar
its already at a local diesel shop.
by time i buy the special tools its just a bit more money to pay to have it done.
not to mention owning my own business it doesnt make money sense to take away from making money to save a little money.
i found a cummins reman 195hp pump for $400. its critical my truck is back up asap as it pulls our eclsoed race trailer. i will send off the failed pump to have it benched/repaired and swap it in at some point.
Old Sep 10, 2010 | 12:55 PM
lil red's Avatar
Mitchell estimating guide calls out 4.7 hrs labor to replace pump and set timing multiply by shops labor rate and there ya go however shops that do alot may have a "flat rate" for replacement hope this help's
Old Sep 10, 2010 | 04:08 PM
crzycummins's Avatar
id say they will tell ya 5 hours and probably about 70 bucks an hour?
Old Sep 17, 2010 | 12:08 PM
goalie990's Avatar
4.5 5 hours sounds about right...
Old Sep 21, 2010 | 03:57 AM
lil red's Avatar
just checking but did you ever get your pump replaced ? I see your in Co. I may be able to help if not.... but jjust checking
Old Sep 21, 2010 | 07:59 AM
co84rc's Avatar
i did,thanks.
it was somewhat of a ordeal but turned out fine in the end. i had ulitmate do it. they werent the cheapest but came highly recommended. there end up being some craftsmanship issues that i had to fix but in the end they made it right with me. i learned yet again i should have just done it myself as usual,but i was weighing the cost of the timing kit vs labor charged and my time away form my business.
