nv4500 -- 4th gear
Old Sep 6, 2010 | 01:28 PM
Rexy's Avatar
Default nv4500 -- 4th gear
Transmission shifts normally 99.9 percent of the time, other .1 percent the transmission seems to be sticking in 2 gears. Did it this morning, last time was 2 months ago. All gears shift fine, except I cant get it into 4th gear. When this happens, the shifter handle vibrates pretty good in 3rd and 5th. Any thoughts? When I shut the truck off , then start it later in the day it will shift like normal.
Update: Went for a drive a while ago, started shifting gears, couldnt get into 4th gear- went on to 5th gear. Drove around for about 10 miles, upshifting and downshifting and never being able to get it into 4th. Went over a set of rough train tracks-- now all gears shift and feel as they should. Any ideas?
Old Sep 6, 2010 | 01:52 PM
94cummins12v's Avatar
sincros maybe i knw mine is extremely difficult to get into first somedays
Old Sep 6, 2010 | 02:29 PM
FastCR's Avatar
Trans is full of the right fluid?
Old Sep 6, 2010 | 02:44 PM
Rexy's Avatar
trans has royal purple, but has the all metal syncros, not the mesh syncos.
Old Sep 13, 2010 | 04:29 PM
Rexy's Avatar
Got it fixed!! 2 bolts on the drivers side of the shifter were loose. Changed fluid as well, and put in thru the top of trans, much easier.
Old Sep 13, 2010 | 05:59 PM
FastCR's Avatar
x2, def the only way to do it
Jun 4, 2015 09:30 PM
rtbcoop
Nov 29, 2014 11:33 PM
GreenDieselF
Nov 9, 2014 07:18 PM
offroad00
Oct 21, 2014 01:48 PM
Oct 18, 2014 10:52 AM
