Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
Coolant issues, need help
Old Sep 6, 2010 | 11:12 AM
usmcdiesel's Avatar
Default Coolant issues, need help
Alright, i just changed my water pump and coolant about a week ago. yesterday i noticed that my water pump is leaking out of the wheep hole. As i investigated, i noticed that my bell houseing was also leeking where the it conects to the back of the block. any ideas on what could be the cuase of this. There is no noticeable leakage around the heads or any of the normal spots. any ideas would be greatly apreciated.
Old Sep 6, 2010 | 11:35 AM
wildbill's Avatar
Did you flush all the crud out before you changed it?? Also, did you use distilled water w/ the coolant, and was it Dexcool??
Old Sep 6, 2010 | 11:52 AM
usmcdiesel's Avatar
i did flush the system. and i used the orange gm coolant u can get at the store.
i had no leaks until i changed the water pump and a complete coolant change.
Old Sep 26, 2010 | 11:11 PM
Rood41x's Avatar
Sounds to me that if you are leaking coolant out the weap hole, that the bearing moved causing the leak(actually quite common) as far as having a leak around the bell housing, change the water pump and clean all the coolant that was leaked out. Run the truck for a few days and see if their is any leaks again.. in my opinion the coolant from the weep hole is blowing back by the fan making it look like you got a leak at the back of the motor.
dwmeehan
Jan 29, 2025 12:13 PM
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
