What does it take to install "tophat" valve seals?
Old Sep 6, 2010 | 10:56 AM
jpfiero's Avatar
Default What does it take to install "tophat" valve seals?
I'm redoing a '93 12v head and the gasket set I got came with "tophat" valve seals. They have a stepped metal tube with the rubber seal installed in the top and are designed to be held down by the valve spring. The head that I have just has the standard rubber cap style valve seals, what would it take to fit the tophats instead of the caps?
thanks
Old Sep 6, 2010 | 12:03 PM
big bad diesel 416's Avatar
Site Sponsor
run the top hats there better for performance
you have to have a little ring machined in the top of the head its no big deal and only about 50 bucks
Old Sep 6, 2010 | 01:25 PM
jpfiero's Avatar
Sounds good, anyone have specs on what needs to be machined? or should I just bring the head and valve seals to the shop and tell them to make it work?
thanks
Old Sep 6, 2010 | 01:38 PM
Site Sponsor
if they know anything about motor machining they will know what to do
also you can have them do a valve job its not a bad idea if its needed have you done your valves? have you checked them? I recommend running a fluid to see if they need work also some specs here about that whole motor
https://www.dieselbombers.com/1st-ge...s-83-93-a.html
Old Sep 6, 2010 | 02:16 PM
jpfiero's Avatar
I lapped the valves and got a good seal, I know a good automotive machinist so I'll talk to him about making them fit.
thanks again
Old Sep 6, 2010 | 06:04 PM
Site Sponsor
your welcome
Old Sep 6, 2010 | 08:21 PM
jpfiero's Avatar
Seriously I really appreciate the help this is turning into a really big project, I just hope it all runs good when it's finished.
I dropped the head off at the machinist and it sounds like he's done it before, it's gonna cost me $45. A set of cap style seals was going to cost me $50.
Old Sep 6, 2010 | 09:03 PM
Site Sponsor
there ya go man money a head and there a better seal because there held down by the spring
RA113024
Mar 13, 2016 07:42 PM
markv8993
Jun 21, 2015 12:24 AM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
twinturbo12v
10
Dec 8, 2014 07:58 PM
