to change tranny fluid or not?
Old Sep 6, 2010 | 09:57 AM
green thang's Avatar
Default to change tranny fluid or not?
i have the e4od tranny and the overdrive is not engaing. on the highway it usually runs 65 at about 2200 rpm and is now almost 2500 rpm. i have not changed the tranny oil before in this truck wondering if it will cause more trouble. or adding a tranny cooler would help.
Old Sep 6, 2010 | 10:47 AM
mxtuner1's Avatar
If the overdrive is not engaging - it is more than the fluid. Of course they will change it when they analyze the problem but there is more wrong with the transmission. Let's hope it might just need a sensor replacement.
Old Sep 6, 2010 | 11:42 AM
it happened the other day was going along the road and hit a pothole and the over drive went off and never came back on. really hope it's not something bad.
Old Sep 6, 2010 | 09:00 PM
mxtuner1's Avatar
I hope for you too - good luck my friend!
Old Sep 7, 2010 | 05:47 AM
everything is working fine just the od is not working any suggestioins need this for work!!!!
Old Sep 7, 2010 | 07:43 AM
tiremann9669's Avatar
Well since it happened when you hit a bump I'd bet it's somthing simple like a wire coming unplugged off the tranny or somthing like that. Does that have the button on the end of the shifter for the OD ? I've seen those go bad on newer trucks
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
PA 24valve
Aug 31, 2015 07:39 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
MBFD 592
Jan 1, 2015 11:37 PM
Bigredpowerstroke
Dec 19, 2014 05:18 PM
