Dual VE's
Old Sep 4, 2010 | 11:25 AM
W150CTDproject's Avatar
Default Dual VE's
yup. the title says it. kicked it around on DTR for a while and came up with a plan. i got a few VE's im watchin on ebay so i can get started. NOT A DAILY DRIVER
2 VW pump pulleys
1 VW VE pump mounting bracket
1 short gator belt
custom spacer/injection pump gear nut to hold the stock gear to the main pump and provide a means to bolt on the VW pulley. (kid in machine class will do it along with my fire rings).
and either full custom lines OR find a way to join 2 sets of stock injector lines right before the injectors.
replace manual with electric fans, move battery to opposite fender well.
Uploaded with ImageShack.us
Old Sep 4, 2010 | 11:29 AM
Lil Red Express's Avatar
HUH really intersting. Hope it works out for you.
Old Sep 4, 2010 | 11:33 AM
if it fails....13 mm p pump
Old Sep 4, 2010 | 01:57 PM
RAW's Avatar
RAW
Yikes! That's a lot of specialized timing to make sure it doesn't know on ya. But then again, they probably need to be a few degrees different for start of injection to end of injection. One thing a coworker and I have talked about is a inline 12 pump, and have the back 6 on dump solenoids. Same theory, different pump set up.
Old Sep 4, 2010 | 08:07 PM
nah, both pumps will be timed and sync'd together. might be a 5-10 degree difference but mostly sync'd together. if both pumps use 14mm heads it'd flow around the same cc's as a mild 13mm pump. i just want something unique. but ill just use 12's for now. it wont be hard, just time consuming. good thing winter's coming
hollywoodbusa
For Sale
Feb 22, 2015 08:03 PM
Slim Whitey
Nov 8, 2014 09:41 PM
94cummins12v
Towing and Hauling
Oct 21, 2014 02:50 AM
Dual Liner
Shade Tree , Pro-Mechanics & Fabrication
Jul 2, 2012 08:36 AM
