1992 f250 7.3L idi IP proplems.Help?
Old Sep 3, 2010 | 01:21 PM
cumminurway's Avatar
Default 1992 f250 7.3L idi IP proplems.Help?
ok i have a 92 f250 7.3L idi i am haveing problems with my injection pump and dont no wat to do to fix my problem so here is the problem. I am not getting any fuel out of the back of my IP i FSS has power and it is not sticking either i had the pump tested through columbus diesel supply also and they said it is working fine but its not working fine in my truck so wat could it be. Thanks!
can sombody please help me i need it i need to get my truck running it is the only vehicle i have to drive
Last edited by cumminurway; Sep 3, 2010 at 01:21 PM. Reason: Automerged Doublepost
Old Sep 6, 2010 | 12:18 AM
Sycostang67's Avatar
Is the lift pump supplying fuel to the IP?
Old Sep 6, 2010 | 12:26 AM
Hyde's Avatar
Like I said before, check your fuel pressure and flow from the lift pump, just cause its new doesnt mean anything.
Old Sep 7, 2010 | 07:41 AM
yes the lift pump is suppling fuel to the injection pump and if u look at how much the lift pump is supplying u can tell it is suppling plenty of pressure
Old Sep 7, 2010 | 11:05 AM
Hyde's Avatar
Watching it come out the fitting isnt a good judge of pressure. Do you know anyone with a gauge?
Old Sep 7, 2010 | 08:39 PM
no i dont my dad probally does and one of my dads buddys is about to have a spear IP he is getting ready to take his out and put a new one in because the one in his truck now is leaking but it still works and every thang so im going to see if it changes any thang with my truck
Old Sep 7, 2010 | 11:29 PM
DieselCrawler's Avatar
did u have ur pump off? was it reinstall correctly? possibly timing off?
Old Sep 8, 2010 | 07:17 AM
well i had it was doing the same thang before i took it out to get it tested
Old Sep 8, 2010 | 10:52 AM
have you tried hotwiring the pump? wire from batt + to FSS. does take a while to fill the ip and lines with fuel before getting it to come out at injectors. last one i did took 4 or 5 tries with cranking it over, 15 seconds at a time then 5 - 10 mins for starter to cool.
Old Sep 8, 2010 | 08:44 PM
yeah i tried hotwiring it before i had it tested and still never got any thang but i never tried doing it several times in a row but i will and i will let u no if there are any changes
gzmak7
8
Apr 7, 2017 03:17 PM
Browe347
Dec 11, 2016 02:59 PM
asajay
Sep 10, 2015 12:08 AM
88 f350 7.3 idi
Aug 20, 2015 09:18 AM
Toms73
Mar 25, 2015 04:36 AM
