no start
Old Sep 2, 2010 | 09:57 PM
bowtech's Avatar
Default no start
i put a new lift pump and fuel filter on and now it wont start it tried to turn over a couple times but nothing now. I dont see any leaks do i need to crack injectors and crank it or some thing? i used the primer pump and pushed it like 500 times probably and it wont squeak.
Old Sep 2, 2010 | 10:29 PM
joey's Avatar
make sure you have fuel at the pump first but if you didnt mess with the injector lines to start with i wouldnt touch em i would take the line loose after the filter. Or just crank on it some more be carful that starter dosent get to hot.
Old Sep 2, 2010 | 11:00 PM
tiremann9669's Avatar
Did you open the bleeder screw on top of the fuel filter housing before you pumped the primer ? If not open the bleeder screw 10 mm wrench, and pump the primer pump until you get straight fuel with no air bubbles and it should start.
Old Sep 2, 2010 | 11:20 PM
bowtech's Avatar
is the bleeder screw the one screw or the big one with the return line on top of it to
Old Sep 2, 2010 | 11:53 PM
The bleeder is the 10 mm screw right on top of the filter housing
Old Sep 3, 2010 | 05:55 AM
94 12valve's Avatar
your gonna need to re bleed your injectors. crack 2 of them till they get fuel.
Old Sep 3, 2010 | 10:29 AM
You obviously are more experienced on a Cummins than I am, but when I replaced the liftpump and fuel lines on my truck I never had to crack an injector line. I just bled it to the filter housing, it started ran rough for a minute and cleared up.
Old Sep 3, 2010 | 11:25 AM
94 12valve's Avatar
Thats just the way I have had the best luck with
Old Sep 5, 2010 | 06:19 PM
bowtech's Avatar
ya i think i found the problem the fuel line was pinched where i put a 3 inch tube of rubber fuel line bc it got twisted when taking off so have to get another fuel line and see
Old Sep 7, 2010 | 01:36 PM
bowtech's Avatar
ok i got a longer piece of fuel line and its not kinked or any thing and when i loosen the bleeder screw (10mm) and pump it a little bit of fuel comes out not much though. when turning it over nothing doesnt even try to start could the new lift pump be bad? what do i do? could it be the injection pump? maybe try to turn the screw up on the back or some thing?
