FP Gauge
Old Sep 2, 2010 | 07:36 PM
silverstreak02's Avatar
Default FP Gauge
Well, first off no I didnt have a FP Gauge but only had the truck for about two months for my vp kicked the bucket. But I gotta new one coming a raptor 100 and a FP gauge from StreetGlow, I guess my question is: Will the FP gauge still connect straight to the vp, and if anyone has installed a FP from streetglow, your input would be amazing because their instructions are very vivid.
Old Sep 2, 2010 | 09:38 PM
tburke's Avatar
Not familiar with street glow but it should go in to your banjo bolt at the injection pump.
Old Sep 2, 2010 | 09:39 PM
RAW's Avatar
RAW
Is this what you are looking for?
http://www.glowshift.com/instruction...sure-Gauge.pdf
Old Sep 2, 2010 | 11:23 PM
Default Re: FP Gauge
You will need a special 90 degree tapped fitting.
Sent from my Cyanogen Froyo using Tapatalk
Old Sep 3, 2010 | 05:17 PM
Sawman's Avatar
2379 If you are going to use electric fuel presure gauge, I recoment getting a snubber valve from summit racing (part #2379). With out this it is only a matter of time being the surge of fuel will junk your sending unit. These are like $18 that is alot cheaper than a sending unit.
Old Sep 5, 2010 | 01:07 PM
thank you all for your input but im still completely lost when it comes to wiring i'm a visual learner and I need pics of a step by step install if anyone has one.
Old Sep 6, 2010 | 04:51 PM
Never dealt with Streetglow so I am not sure if you even have all the parts required.
Old Sep 17, 2010 | 04:33 PM
ok so i got the fuel line from genos on the back of my gauge with the wiring i have a hot wire(red), Illum wire(orange), sending unit wire(green), ground wire(black) I know you can tap into the fuse box with the add a fuse but which one is the best and what did everyone else use for good grounds?
Old Sep 20, 2010 | 03:38 PM
ok i cant get the damn thing to sweep or anything would just a regular 0-16 psi fp gauge work? what should my fp be at idle i know it should be at least like a 12 or 13 at full throttle correct?
Steve123
Sep 28, 2015 02:36 PM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
450r racer
Nov 14, 2014 05:11 PM
scottxmorris
Oct 8, 2014 02:14 PM
