Making 94 Dodge Diesel the Bomb
Old Sep 2, 2010 | 09:26 AM
War742's Avatar
Default Making 94 Dodge Diesel the Bomb
hey everyone, I find that my 94 Dodge 2500 is under powered. I am going to rebuild the engine now after 258 thousand miles. Can you give me some advised on what to focus on for a strong reliable engine with alot more power.
Old Sep 2, 2010 | 09:56 AM
300k and low power doesnt necessarily mean that you need to do a rebuild. The Cummins is a medium duty diesel and should be able to do near double that without a rebuild. A compression test will help determine if you actually need to do a rebuild.
12V's (94's especially) dont have a lot of power. IMO, you could have some issues that need to be addressed. You should do a compression test and if thats good - start bumping the power up.
Old Sep 2, 2010 | 11:01 AM
94 12valve's Avatar
what kind of power are you looking for?
I put new rod and main bearings in my 94 at 180k only because the motor was already out of the truck. When I took them out the looked brand new, could have gone at least another 180k before they needed changed.
Old Sep 2, 2010 | 11:31 AM
12vcummins96's Avatar
my buddy has 600,000 on his and its still runnin strong
Old Sep 2, 2010 | 11:49 AM
94 12valve's Avatar
thats awesome
Old Sep 2, 2010 | 12:21 PM
War742's Avatar
so if I am looking for raw power out of this engine. What should I do?
Old Sep 2, 2010 | 12:41 PM
my opinion is start with guages then a fuel plate a modified afc timing advance injectors exhaust an intake turbo what kind of power range you lookin for do you have an auto or a standard do you tow alot what are your plans???
Old Sep 2, 2010 | 12:59 PM
94 12valve's Avatar
Old Sep 2, 2010 | 01:59 PM
oglejust's Avatar
Umm raw... didn't u read his post
Old Sep 2, 2010 | 02:18 PM
94 12valve's Avatar
"Raw" as in no turbo?
