tranny exchange cooler
Old Sep 2, 2010 | 12:21 PM
cumminspwr11's Avatar
Default tranny exchange cooler
im in the process of rebuild my two forward clutch packs and putting a shift kit in the vb, i bought a new sonnax manual valve that will allow the tc to charge while in park, the directions say to remove the check valve that is below the tranny exchange cooler so that the tc doesnt shudder and what not, im thinking about deleting the whole thing all together, ideas on this??? good or bad?
im taking about the tranny fluid to engine coolent exchange cooler that is located on the side of the block under the turbo, it allows that tranny fluid to heat up to the engine temp so they run roughly the same
Last edited by cumminspwr11; Sep 2, 2010 at 12:21 PM. Reason: Automerged Doublepost
Old Sep 2, 2010 | 12:25 PM
12vcummins96's Avatar
you can delete it but i would recommend an aftermarket cooler on the outside of the condensor to help with cooling
Old Sep 2, 2010 | 08:18 PM
i already have one off a 6.0 mounted up under the bed side with daul 10" fans, the cooler its self is 3/4" thick by 18" long and 12" tall
should i plug off the engine cooler lines or loop them together?
Last edited by cumminspwr11; Sep 2, 2010 at 08:18 PM. Reason: Automerged Doublepost
Crabber0001
6.0L Performance
Aug 4, 2015 12:30 PM
Bighouse
Apr 9, 2015 06:51 PM
mcompton1973
Feb 11, 2015 12:00 PM
bypass-21
Dec 15, 2014 08:52 AM
Ol' RED!
Dec 11, 2014 10:00 AM
