quadzilla pulse tuning
Old Sep 1, 2010 | 12:43 AM
kegs99's Avatar
Default quadzilla pulse tuning
installed my quadzilla adrenaline with pulse tonight. i was wondering how exactly i should set it all up. i have the tire size, and set the turbo timer to egt cool down at 375 degrees. what should i set my alerts at and everything else? also i can install the trans temp in the oil filter spot thing. should i do this since its a stick, or should i put it on the tranny? thanks guys. also any tips for drilling and tapping the egt probe spot would be great!!
Old Sep 7, 2010 | 12:25 AM
DieselWeasel's Avatar
"Ohio Bombers" Director
If you have a stick shift you should have bought the one for a stick shift... Then that probe goes into your OIL temp. Only time it goes into trans is with the AUTO. Its wired in their harness i believe to be either or. You can set your warnings to whatever you want... I have back down on mine at 1200* on EGT but never see that... Even running stage 10 on the 3k tunes from their site. Thats slamming 38psi of boost max down the pipe too! Did you get the fuel pressure gauge they offer too? I need to get it myself! I have a POS one on the dash for now.
I have to call them on mine, because if temp goes over 210* it blanks out to 0! Thats bad... since i had my alarm at like 215 or something!
Old Sep 7, 2010 | 08:00 AM
RAW's Avatar
RAW
Is this limitations in the truck, or their circuit? I know my Edge Juice w/Attitude will not read over 200F of coolant temp, due to the limitations of the truck's computers.
Old Sep 7, 2010 | 02:39 PM
01quadcab's Avatar
my juice would read over 200 my max temps going back and looking at them was recorded at 225 once. so not sure whats up with yours.
Old Sep 7, 2010 | 02:43 PM
Jazz's Avatar
If I remember right I think my adrenaline would blank out or go to zero (Just engine temp rest of the readouts are fine) when my engine temp hit 201
Old Sep 9, 2010 | 04:43 PM
PLMCRZY's Avatar
If you go on Quadzillas website they have a update for the pulse that should fix that. I had to do it to mine.
As far as setting the quad up, personally i would just download a tune and not mess with unless you have it stacked with something like a smarty. I have mine stacked and it fuels down low so much, i adjusted the adrenaline to come on a little later.
Old Sep 13, 2010 | 09:00 AM
kegs99's Avatar
you don't order for just a stick or just auto, the module is set up to do either or, i was wondering where was the most sensible place to use it on a stick. i probably won't install it in either anyways, not a big deal. My pulse is not working right or something, i'm running the adr2-3000 tune and the turbo timer isn't working!! what do i do?? also it will be running in a stage and when i get on it, it starts droppin to lower stages!! even in stage one it drops to 0 and flutters between the two until i let off then goes back to 1
dodge1998
Jun 13, 2016 12:25 PM
Baradium
Dec 14, 2014 05:04 PM
Nov 30, 2014 02:10 PM
MAC4232
Oct 16, 2014 04:22 PM
estill03
For Sale
Oct 3, 2014 09:58 PM
