turbo rebuild problem
Old Aug 31, 2010 | 03:56 PM
jaytric9's Avatar
Default turbo rebuild problem
I have everything back together and so close to being done and having it on the road again. When we had it all said and done (before housings went on) we tightened the nut down that holds the compressor wheel on and its tightening everything to where the wheels cant spin. there has to be something missing? is this common with something certain not put back together right? I cant figure it out for the life of me.....
Old Aug 31, 2010 | 05:01 PM
RAW's Avatar
RAW
The comp wheel should bottom on the shaft when tight, and not hit the housing. If it does, I'm guessing something is preventing the shaft to protrude through the center section enough. Hanging up on bearings, or something cought behind the exh wheel and housing.
Old Aug 31, 2010 | 05:51 PM
jaytric9's Avatar
well ..... does the exh wheel lock into the housing with and snap ring like piece? If so could that be the problem not having a good snap ring?
Old Aug 31, 2010 | 06:15 PM
Farmboy 2.0's Avatar
heres a link to a write up that might help
DIY: How to Rebuild Your HX35. - Dodge Cummins Diesel Forum
Old Aug 31, 2010 | 06:33 PM
jaytric9's Avatar
this should help a little. but ive followed what he did and the only thing i can think of is the retaining clip on the shaft being bad and not locking it in so to speak.. would that be enough to messed up the wheels locking when trying to finish up?
burndiesel
10
Feb 7, 2023 01:15 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
Whitereaper12v
Jan 28, 2015 11:01 AM
GreenDieselF
Oct 20, 2014 02:05 PM
