causes for over heating help!!!!!!!!!!!!!!!
Old Aug 31, 2010 | 02:27 AM
overheated's Avatar
Default causes for over heating help!!!!!!!!!!!!!!!
i have a 1995 6.5 turbo desile chevy half ton we have only had the truck about a year and half and in the last couple monthes we have had an over heating problem,my husband has changed the theromastate,waterpump,clutchfan, and we still have the over haeting the temp stays at 210 and over unless the mortor is idaling not sur what to think any answer would be a great help
Old Aug 31, 2010 | 09:53 PM
Woody35's Avatar
have you cleaned the radaditor. duramax fan moves more air too
Old Sep 4, 2010 | 10:34 PM
rescueeskew354's Avatar
Radiator could be plugged , and the Duramax fan does move more air . Have you tried a new temp sensor . Also that truck wont last long running at 210 degree temps . Could be the start of a head gasket going bad
Old Sep 5, 2010 | 01:07 AM
goobs's Avatar
i had the same problem, it ended up being my radiator, had three tiny holes above the drain plug. it could be a faulty rad. cap
Old Sep 15, 2010 | 12:09 AM
Walking J's Avatar
Yes, radiator is likely plugged between the radiator and the AC condensor. Should remove the radiator and clean thoroughly with scrubbing bubbles and a hose.
Good luck!
MFARRENS
Jan 27, 2015 07:35 PM
JPT99
Nov 18, 2014 07:26 PM
Bigredpowerstroke
Nov 12, 2014 03:33 PM
