Trans wont shift
Old Aug 30, 2010 | 07:56 PM
cumminsCrazy's Avatar
Default Trans wont shift
okay so my truck will start out in first but wont go above 30 mph and im at 3000 rpm at that speed. i cant seem to get it to shift i dont know what to do any help would be great thank
Old Aug 31, 2010 | 02:02 AM
big willy's Avatar
when is this happening all the time or a certain times?
Old Aug 31, 2010 | 06:42 AM
all the time it feels like i only have first gear could it be electrical?
Old Aug 31, 2010 | 09:06 PM
posmx's Avatar
i could almost guarantee its the crankshaft positioning sensor (aka throttle positioning sensor) or tps
just replaced mine, wouldnt allow torque converter to lock up or shift into forth, shifts great now...
Old Aug 31, 2010 | 09:46 PM
bobcat67's Avatar
do you have reverse and stuff? cause mine is doing the same thing right now only i can go 40 in first which happens to be the only gear i have
Old Aug 31, 2010 | 10:33 PM
i have reverse and that just wont shift outta first
Old Sep 1, 2010 | 11:35 AM
bobcat67's Avatar
oh ok you're is different than mine then
Old Sep 1, 2010 | 08:19 PM
Fairmont's Avatar
check your detect cable
Old Sep 1, 2010 | 09:13 PM
cable is good if i unplug center plug on the pcm it can shift manually but no overdrive cause thats controlled throught the computer right? does this sound like a computer problem?
Old Sep 1, 2010 | 09:18 PM
tltruckparts's Avatar
a crank sensor is completely different than a throttle positioning sensor. i would check the sticky on how to adjust the tps and see it that helps. but i believe 1st through 3rd are all hydraulically controlled and then electrically controlled in 4th, OD and also torque converter lock up. check the plug on the transmission and find out which wire is the keyed power source for the tranny plug. start there and make sure your transmission is gettin an electrical signal. im not a transmission specialist so unfortunately i cant help a ton but if im remembering correctly (1st-3rd being hydraulic) id say you have some sort of internal transmission problem.
have someone in the truck shift it through the gears and lay underneath it and make sure the tv cable is moving as it should. it might just be jamming and only allowing it in first
