Another VP44 death?
Old Aug 30, 2010 | 07:19 PM
Budgetbuilt's Avatar
Default Another VP44 death?
So I just put new 5" exhaust on and went to take it for a test drive. I got out on the road and was fine. Stopped and brought it up to 15 pounds of boost and let the brake off, I went 30 feet and it cut right out and died. Wont start and I got code po253. Is this the end of the VP44? Any help would be great Thanks
Old Aug 30, 2010 | 10:55 PM
00' Quad Cab's Avatar
P0253 Fuel Injection Pump Fuel Valve Open Circuit
I believe that would be one of the worst codes to see.
Old Aug 31, 2010 | 09:08 AM
moparious maximus's Avatar
Another vp-44 bites it hard.
Sure sounds like a siezed rotor to me.
Do you know what the fuel pressure was doing? Thats what usually does it.
Old Aug 31, 2010 | 05:33 PM
I didnt have a fuel pressure gauge hooked up . But i cleared the codes again and got p1688 "Internal fuel injection pump controller failure". I just got into the diesel trucks so I dont no much. I do no I needed a fuel pressure gauge though.
Old Aug 31, 2010 | 05:39 PM
Farmboy 2.0's Avatar
What are you running for a lift pump?
Old Aug 31, 2010 | 06:45 PM
kazairl's Avatar
according to Blue Chips Diagnostic Page, If you have a 1688 Code and the truck won't start, You need a new VP.
Old Aug 31, 2010 | 06:47 PM
Sad to say but it's shot.
Old Aug 31, 2010 | 07:24 PM
silverstreak02's Avatar
I'm in the process of removing my vp as we speak I've got a t bar hooked up to pull off the pump from the timing cover i've removed all 4 nuts holding the vp and 2 bolts from the mounting bracket but i keep turning the bar and it just wont pop its loose i can move it back and forth with my hand but i've use everything and it still will not just pop, i dont want to break it should i keep going or what?
Old Aug 31, 2010 | 07:28 PM
kazairl's Avatar
Did you remove the nut holding it to the gear?
You did remove the injection lines right?
Old Aug 31, 2010 | 07:42 PM
yes removed the nut and washer holding it to the gear and removed all the injection lines correctly
