What next??
Old Aug 30, 2010 | 06:58 PM
24vmatt's Avatar
Default What next??
with my current setup what should my next mod be??
Turbo or injectors???
And what kinda of turbo and injectors..
I like the Super b special..
And i was thinkin 100 hp ddp sticks..
This is my daily driver,i have a very heavy FOOT, and love to drive her hard....
I pull 3500-7500 lbs on occasion.
I dont want to sacrafice drivabilaty!!!
Thanks,
Matt
Old Aug 30, 2010 | 07:03 PM
RAW's Avatar
RAW
I think your on track with 100's and a Super B Special. Could save a little cash and get Fireballs!
Old Aug 30, 2010 | 08:43 PM
24vmatt's Avatar
Iam gunna go with luke for all my future mods!!
Thanks!
Any more input guys???
How do u like ur Banks Wastegate? did u notice a diff and is it worth the $$$
Old Aug 31, 2010 | 01:23 AM
Farmboy 2.0's Avatar
Id look into a 62mm turbo. I think a super b special with only 100 horse sticks would be alittle laggy ecspecially for towing. My 62 was aweosme when i just had my 75's. Now its way to small
Old Aug 31, 2010 | 07:46 AM
RAW's Avatar
RAW
The wastegate came on the turbo when I bought it, so I don't really know a before and after. I can only make 36 PSI boost with my set up, and the actuator is set to 42 PSI. IMO, a waste of money, just plug the wastegate hose.
Old Aug 31, 2010 | 09:10 AM
24vmatt's Avatar
what is a safe boost # for me to run?
Old Aug 31, 2010 | 10:30 AM
RAW's Avatar
RAW
with Banks making an actuator that opens at 42 PSI, I'd say they think that that is the limit. I'd agree, if not a little less. 38 maybe, your running into headgasket danger past 40. Not to say it will blow at 40 on the nose, but fatigue will happen over time.
Old Aug 31, 2010 | 10:42 AM
I don't recommend running over 40psi without headstuds. Most people say you can go past 45psi but i don't trust that. I prefer to see 34 to 36 with stock head bolts. Head gaskets are a pita if you blow one you need to get the head decked and maybe the top of the block as well IMO
Old Aug 31, 2010 | 11:24 AM
Depending on your goals but a 62mm turbo and 100-150hp injectors work great. A Super B Special will be a bit laggy.
Old Aug 31, 2010 | 12:26 PM
GuyWithA24Valve's Avatar
If i plugged the waste gate hose on my truck, would i need to worry about making too much boost for not having head studs?
