Lift Pump Symptoms
Old Aug 30, 2010 | 05:34 PM
bowtech's Avatar
Default Lift Pump Symptoms
what happens when its going out? my truck started sputtering then it got to where when you put it in drive it idles rough i changed my fuel filter just a few ago and it was half full of fuel shouldnt it be full? how hard or long does it take to change the lift pump? whats to it?
Old Aug 30, 2010 | 07:00 PM
spetersen502's Avatar
Its going out you need to change it asap you dont ever want to run it long periods of time its not good at all on your pump i would suggest an upgrade to an airdog their the best
Old Aug 30, 2010 | 08:53 PM
phil's Avatar
i put a post up about our lift pump about a week ago, you should check it out because mine was doing the same as yours. its called truck would not start, figured out the problem.
Old Aug 30, 2010 | 10:36 PM
jrad989's Avatar
is it the original pump? how many miles are on it?
Old Aug 31, 2010 | 01:38 PM
bowtech's Avatar
no it was changed a while ago a year or two
Old Aug 31, 2010 | 01:46 PM
NadirPoint's Avatar
The only way to know what a fuel pump is doing is with a fuel pressure gauge.
Old Aug 31, 2010 | 04:09 PM
bowtech's Avatar
it tricky to swap out lift pumps? any tricks or it straight forward bolt of bolt on
Old Aug 31, 2010 | 04:27 PM
NadirPoint's Avatar
2 bolts, 2 line connections, piece 'o cake.
Old Aug 31, 2010 | 08:07 PM
bowtech's Avatar
do you have to prime it or some thing? just pump it then crack injectors or what?
Old Sep 1, 2010 | 06:44 AM
NadirPoint's Avatar
You may or may not have to prime anything. Just change it and crank, see if it fires.
