Tell me what turbo to run
Old Aug 30, 2010 | 03:40 AM
bryson's Avatar
Question Tell me what turbo to run
'01 24v auto, DDP 110s, Edge J/A, AirDog, 3.54s and 35" tires... Daily driver.
I've got a HE351 on it now (60/60/9) and it seems to me that there is not enough air to make things run happy. It's a smokey pig, and the EGTs aren't awesome. Even with low-boost fuel turned down, I think there is way too much fuel to let the turbo light, and even when it does, the smoke is far from gone. I tow some, usually about 5k lbs, and on rare occasion up to 10k. I live @ about 4500 ft elev, and often drive/tow higher than that. Lots of hills/mountain passes. Not much for sled pulling or racing, but I'd like it to be fun to drive still.
I'd like input on what turbo would be a good fit for my setup. Don't want it to be too laggy, and I need manageable EGTs. I'd love twins, but that isn't in the budget right now. So, what's a good single to run and why?
Old Aug 30, 2010 | 04:14 AM
biged681985's Avatar
id say a 64/65/12 would be a good set up with what ur running
Old Aug 30, 2010 | 07:31 AM
RAW's Avatar
RAW
Agreed, a larger exhaust housing would benefit you! I went from a 9cm HY35, to a 12cm HX35 and liked the results.
Old Aug 30, 2010 | 09:06 AM
kazairl's Avatar
Honestly I think your biggest help would be to switch to 4.10s. You'll give up a little on the top end but I think you'll like the acceleration a bit better. A manual can get away with running those higher gears. An auto with a tight converter, not so much.
Old Aug 30, 2010 | 04:57 PM
bryson's Avatar
4.10s are certainly in the plans, but do you think the 3.54s would be the sole reason for my lag?
Old Aug 30, 2010 | 11:06 PM
kazairl's Avatar
I haven't driven your truck So I don't know your definition of lag. A guy I know has a 3.55s 37in tires and about the same fuel and air setup as me and loves it. Lag is pretty subjective.
Have you ever tried leak testing your air system? A HE351 should spool pretty fast. You might have an air leak between the turbo and the engine or possibly have a cracked exhaust manifold or maybe a leaking gasket? All those could be part of your problem. Elevation doesn't help you out much either.
What is your max boost?
Old Aug 31, 2010 | 12:49 AM
bryson's Avatar
Intake system is tested and tight up to 40lbs, and I can't find any evidence of the exhaust side leaking either. Max boost (as displayed on the Edge J/A which I know may not be very accurate) is 35#.
Elevation is definitely not helping, but isn't this turbo one that should work better than most in this case?
I wonder if I just have a bunk turbo?
Thanks everyone for the help.
Old Aug 31, 2010 | 12:56 AM
Farmboy 2.0's Avatar
62/71/14 would be a good choice. You might be overfueling that turbo in the low end.
vin_diesel
Mar 1, 2016 01:43 PM
n2brk
Feb 21, 2015 09:05 AM
schearer350
Feb 12, 2015 12:27 AM
GreenDieselF
Oct 20, 2014 02:05 PM
wvwelder89
Oct 8, 2014 01:22 AM
