Normal or about to explode?
Old Aug 29, 2010 | 02:21 PM
jpfiero's Avatar
Default Normal or about to explode?
this is what my flywheel looks like:
Never seen any thing like this before, but I've only done clutches on small cars. The clutch disc looks great I was planing on just using this clutch, flywheel and pressure plate for a few more years, but I don't want it to blow apart and take out my tranny.
Do you think it will last? I won't be making more than 300hp and don't tow trailers often.
Thanks
Attached Thumbnails Normal or about to explode?-flywheel.jpg   Normal or about to explode?-flywheel-crack-1.jpg   Normal or about to explode?-flywheel-crack-2.jpg
Old Aug 29, 2010 | 02:23 PM
rednekroper05's Avatar
get a new one a flywheel should never be used with cracks like that.
Old Aug 29, 2010 | 03:37 PM
motorboat's Avatar
Surely you jest! Get a new one, and you wil need a new clutch as well. Consider yourself very, very fortunate. BTW, did you remove them because of chatter? If so, you found out why.
Old Aug 29, 2010 | 05:16 PM
man that flywheel looks worse than my last stocker when i burnt that clutch up. and a piece of advice from experiance go ahead and replace the clutch and flywheel with a unit that is a little stronger than what you need cause burning up clutches is not cheap.
Old Aug 29, 2010 | 10:51 PM
jpfiero's Avatar
Alright, does anyone have any info on upgrading to the 13" clutch and/or a good place to pick up the parts? I see the kits on ebay for $400-$500 but not sure if they are any good.
Can I just pick up the parts from my local parts store or are they a custom thing?
Old Aug 29, 2010 | 11:14 PM
i used a valair 13" upgrade on mine it was like 650-700 orded straight from them but ask for a quote on here im sure the sponsers can hook you up. it was a good clutch better than the centerforce i put on before.
Old Aug 30, 2010 | 01:44 AM
jrad989's Avatar
thats looks all sorts of bad.
Old Aug 30, 2010 | 01:55 PM
12valvetater's Avatar
It doesn't look that bad to me.
Old Sep 1, 2010 | 02:58 PM
NadirPoint's Avatar
A few hairline surface cracks are normal and may safely be ignored.
But not those!
Old Sep 1, 2010 | 03:23 PM
Dirt_Diver's Avatar
I suggest buying a double disc just because your never gonna have to worry about the clutch again but if money is tight likewise stated
