Are all 12v heads the same?
Old Aug 29, 2010 | 10:49 AM
jpfiero's Avatar
Default Are all 12v heads the same?
Can I use a '93 cyl. head as a direct replacement for a '96 engine?
I've got a '96 cylinder head that I was going to use on a good '93 block, but when the '96 blew, the #6 piston hit the head hard enough to crack the piston. I have a good head from the '93 block but I want to make sure all the accessories from the '96 head will swap directly onto the '93 head.
Thanks
Old Aug 29, 2010 | 08:47 PM
12valvetater's Avatar
No they aren't all the same. Pretty sure you will have to bush your injectors.
Old Aug 29, 2010 | 10:46 PM
jpfiero's Avatar
Do you know what the difference is?
By bush the injectors do you mean install bushings around the newer/smaller injectors, or that I will have to get new injectors and throw out the old ones?
From what I have read the early heads had 9mm injectors but they switched to 7mm injectors before '93 and have been 7mm ever since. I would like to find out exactly what the difference is (if any) before I attempt to use the '93 head.
Thanks.
Old Aug 30, 2010 | 11:25 AM
goalie990's Avatar
The first gen head wont work on a 2nd gen directly but like stated about I think the only difference is the injector size.
Old Aug 30, 2010 | 11:55 AM
NadirPoint's Avatar
91.5 and up 12v heads have 7mm injectors.
Old Aug 30, 2010 | 09:30 PM
jpfiero's Avatar
Ok, so that means that this '93 head should work I guess I'll try one of the injectors and see if it will fit, one of the valves is bent in my '96 head and I will need to get it magnafluxed if I'm going to use it.
Old Aug 31, 2010 | 07:02 PM
smoken's Avatar
Hey sorry for ur bad luck,,, how did you crack the #6 piston to much off what thanks...
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
greatlakes diesel
Feb 13, 2015 09:55 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
detroitdiesel idi
Dec 27, 2014 10:03 PM
Oct 30, 2014 08:10 AM
