drain problems?
Old Aug 28, 2010 | 10:08 PM
kyle davis's Avatar
Default drain problems?
when doin twins can i run both drains into the origional drain or do i HAVE to pull the other plug? if so what do i need to put in for an apdapter since this is a total diy install
Old Sep 3, 2010 | 06:44 PM
kyle davis's Avatar
can anyone help or am i on my own?
Old Sep 3, 2010 | 08:11 PM
turbo20psi's Avatar
No you can run the drains(return) into the original drain with a set of compounds not twins.The hot oil won't care once it goes down the return.
Old Sep 3, 2010 | 08:16 PM
RAW's Avatar
RAW
Correct, with COMPOUNDS..... you can run both returns to the same port in your block. I suggest you do it as close to the block as possible.
Old Sep 3, 2010 | 09:28 PM
thebullet83's Avatar
why can't you run twins together? a drain is a drain right? compounds or twin?
Old Sep 3, 2010 | 10:11 PM
RAW's Avatar
RAW
That is true, any two turbos could utilize the same drain. Even sequential turbos.
Old Sep 4, 2010 | 12:36 AM
kyle davis's Avatar
well i wanted to use the stock drain because im not postive that the twins will work and dont wanna unplug the other hole in the block if they dont .... i just wanted to make sure that the drain could flow enough oil for both drains...
Old Sep 7, 2010 | 11:47 PM
crazycooter's Avatar
If not, you would only end up with excess oil in your turbos, only a real problem I guess in a ball bearing turbo, being that more oil = more drag = slow spool = less boost???
Old Sep 8, 2010 | 05:27 PM
kyle davis's Avatar
no more problems i seem to have it together went for a test drive and blew the turbo out to the intercooler and just gotta put some ribs on the smooth pipe but it was awesome till the boom, but i love the whistle
Old Sep 9, 2010 | 02:32 PM
24vmatt's Avatar
