could the cylinder head survive this?
Old Aug 27, 2010 | 10:43 PM
jpfiero's Avatar
Default could the cylinder head survive this?
this is what the number 6 piston looks like after punching the head at highway speed:
and this is what the head looks like:
Do you think the head survived?and can I use a head off of a '93 to replace it if not?
and if your interested this is what the block looks like:
notice part of the cam was pushed out through the hole
Attached Thumbnails could the cylinder head survive this?-punched-head-small.jpg   could the cylinder head survive this?-cracked-piston-small.jpg   could the cylinder head survive this?-hole-block-small.jpg
Old Aug 27, 2010 | 10:54 PM
Pyro690's Avatar
Old Aug 28, 2010 | 12:14 AM
wes-cummins's Avatar
get it magnafluxed
sry about your motor man
Old Aug 28, 2010 | 12:59 AM
captain_stabbin's Avatar
what happened man
Old Aug 28, 2010 | 03:38 AM
97cummins's Avatar
Old Aug 28, 2010 | 08:33 AM
jpfiero's Avatar
I might have to get it magnafluxed, but I'm not sure if the valves would have been bent. They look fine and I think I know how to check them, but it may be easier to just swap on the good '93 head I've got, do you know if it will fit? it looks the same to me.
I bought the truck with a pushrod hanging out of the oil pan, the guy I bought it from claimed he heard a noise in the top end while cruising down the highway, he then turned around to get home, went about a mile and heard a loud bang
Thanks
Old Aug 29, 2010 | 08:43 PM
12valvetater's Avatar
Valves are cheap replace them. The head looks fine have it checked though.
Old Aug 31, 2010 | 09:12 PM
angelic0-'s Avatar
shouldn't the valves from your 93 head fit into this head if these are bent... head doesn't look all that bad..
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Adam65
Jan 9, 2015 11:50 PM
Oct 31, 2014 08:10 AM
Oct 13, 2014 08:10 AM
