Tachometer Output
Old Aug 27, 2010 | 01:42 PM
Edahall's Avatar
Default Tachometer Output
Is there a tachometer output on the alternator like on the Chevy's. I want to install a tachometer but need a signal.
Old Aug 27, 2010 | 09:40 PM
1stGen1990's Avatar
What year is your truck? i know the intercooled ones have a plug under the dash, and non intercooled require a sensor to be mounted on a oil pan bolt and read off the harmonic balencer, and like you said some use the alternater. Personally i would find the sensor kit for the barmonic balencer and use that instead of the alternator one.
Old Aug 27, 2010 | 10:06 PM
sweetv8s10's Avatar
Where is the plug in at under the dash located?
Old Aug 28, 2010 | 02:03 PM
RSWORDS's Avatar
It`s a flat 4 pin connector under the steering column, look around some, its not always directly under it.
Old Aug 28, 2010 | 04:02 PM
Edahall's Avatar
My truck is a 1990 Chevy Cummins. It has a Non intercooled 1990 Cummins engine and a 2001 NV5600 from a Dodge truck.
It sounds like there is no hook up for tachometer on the alternator so I may have to look at the alternate means mentioned.
Old Aug 28, 2010 | 09:05 PM
RSWORDS's Avatar
I run the Isspro that reads off magnetic pick-ups on the harmonic balancer. Works great and was very easy to install.
Here is the link to my write up...
https://www.dieselbombers.com/5-9l-r...uge-mount.html
Old Aug 29, 2010 | 09:11 PM
sweetv8s10's Avatar
Where can I get a tach that fits my factory plug?
Old Aug 30, 2010 | 06:38 PM
RSWORDS's Avatar
Isspro has them, most of our sponsors can take care of you with great pricing and AWESOME service!
Go here to request a price quote!
Price Quote - Request A Price - Diesel Bombers
Old Sep 2, 2010 | 10:29 PM
mkriebs's Avatar
YOu can run it off one of the brushes on the alternator. My brother did it that way.
Old Sep 3, 2010 | 10:19 AM
Edahall's Avatar
Yeah, I'll probably open up the alternator and make my own tachometer output as your brother did.
