need help
Old Aug 27, 2010 | 12:35 PM
fravelj's Avatar
Horn need help
I found a junked 94 turbo diesel 7.3l idi i beileve how do u take the turbo and everything u need for the turbo off that truck? and how do u put them on my 89 f250 7.3l idi? if anyone knows please reply if u know where i can atleast read how to that would help too.
Old Aug 27, 2010 | 01:16 PM
DieselCrawler's Avatar
just unbolt it all. nothing is hidden. there are 2 bolts in the bottom of the air cleaner assy, but other than that it is all obvious.
Old Aug 27, 2010 | 01:26 PM
fravelj's Avatar
do u have to take the top off?
Old Aug 27, 2010 | 01:53 PM
yea, three bolts hold the lid on. remove them and the clamp on the turbo. then remove upper lid. remove air filter. 2 bolts on bottom of box. remove bottom of box and CDR tube. remove driverside valve cover. remove 2 bolts into back of original intake that hole oil return line. also while back there remove the v clamp holding down pipe to turbo. now go under, remove up pipes from manifolds and turbo. drop up pipes down, pull turbo out the top.
Old Aug 27, 2010 | 02:09 PM
fravelj's Avatar
i dont think i can get under it could i remove the up pipes from the top ? cus its in a junkyard
Old Aug 27, 2010 | 02:30 PM
cowboyford16's Avatar
No has to be under it
Old Aug 27, 2010 | 04:17 PM
junk yard should pick it up for u. they do for me at every yard i go to.
Old Aug 28, 2010 | 08:52 AM
fravelj's Avatar
this ones in the mountains but i could take a jack with me that would work wouldnt it?
is it easy to get to under it ?
Old Aug 28, 2010 | 09:26 AM
is it t2wd or 4wd? 4wd will make it a little more challanging.
Old Aug 28, 2010 | 05:55 PM
fravelj's Avatar
im not sure but i dont think it has and front wheels on it
i think im going to go early monday morning and get it how long u think it would take to get off as long as everything goes good?
