Wastegate stuck closed.
Old Aug 27, 2010 | 09:25 AM
Chris_ce's Avatar
Default Wastegate stuck closed.
My wastegate is stuck closed. My boost is around 28-30 when stepping on it. My question is will there be any damage if I don't fix it? I was thinking about a boost fooler so that I get my power back from the defueling. Do I need to worry about anything? Truck has been this way for a good while now and I have hualed with it. It does good on the highway but when I climb hills in second gear(automatic) It just doesnt have any power. I think from the defueling that the computer is doing. When in second and climbing the hills I think it is setting the code P0234.(overboost). Anybody have any knowledge about this?
Old Aug 27, 2010 | 10:53 AM
RAW's Avatar
RAW
Many people have run their turbos with plugged or wired shut wastegates, and I'm one of them. I have never noticed any damage and I check my turbo at every oil change. An electronic boost fooler would be the way to go to relieve the defueling.
Old Aug 28, 2010 | 12:22 AM
wes-cummins's Avatar
30 psi isnt pushing a 35, itwont hurt ur turbo byleaving it like that
Old Aug 28, 2010 | 10:15 AM
J-Pipes's Avatar
Might as well just go ahead and get yourself a nice tuner or module that already has a boost fooler built in-seems like this could be a good excuse to spend some money!
Old Aug 28, 2010 | 02:59 PM
Chris_ce's Avatar
Thanks guys. I ordered a Quadzilla boost fooler today so I will let you know the results after I get it installed.
Old Dec 22, 2011 | 01:34 AM
rollincoal12v's Avatar
It wont hurt the stock turbo or the cummins engine to run 30psi of boost but dont run to much more then that stock exspecily with an automatic trans if it dont have much power pulling u might want to invest in a programing chip but if you get a chip an your turning up the fuel i would be sure to have gauges or you will more then likely blow the turbo or burn a piston if you dont want to do any of that take it to a shop to have the wastgate fixed I have a 97 12v 3500 i pull with alot and its turned up an im running 35-40psi an have had no problems with it but i watch my gauges an dont push the truck to it max for very long eather
Old Dec 23, 2011 | 12:13 PM
AllWeatherBomber's Avatar
my wastegate is clamped shut as well and i regularly hit 35-39 lbs of boost. i have had no problems yet ( been about 6 Months) the only thing i notice is the turbo chug when you are beating the **** out of it at high revs and boost and let off suddenly and all that boost has no where to go. once and a while i dont think will hurt it, but i have also heard horror stories of exploded turbo wheels too. BUT...i am not a mechanic.
For the highly technical easily explained ...i find RAWilliams very helpful.
Woodsracer
Ford Powerstroke 2011-Up 6.7L
Jul 30, 2017 09:14 PM
bosse777
Sep 28, 2015 05:38 AM
6.2Lturbo
Chevy/GMC Duramax 01-04 LB7
Aug 15, 2015 01:25 PM
Bottlerocket12v
Mar 12, 2015 09:10 PM
wpg6.5
Feb 19, 2015 07:27 PM
