Leak Down with Head OFF
Old Aug 27, 2010 | 08:31 AM
bigdan120's Avatar
Default Leak Down with Head OFF
I recently pulled the head off my 5.9 12v and I was hoping to find a bad valve or bad head gasket well no surprise my My bucking I have doesn't look like it is coming from there. Gasket looked good. No bent valves. So a mechanic told me dump diesel in the cylinders and see if it holds. Well lets say cylinder 2/4 went down in about 2 hours 1/3/6 next day 24 hours and 5 48hrs. Any insight. Obviously it is not a scientific experiment but sounds like my rings are shot. The cylinder walls still have hatch marks in them and it is std bore. What you think. I also noticed that 4 out of 6 injectors that are new 1 month were covered in black crap 2 were as clean as the day i put them in.
Old Aug 27, 2010 | 09:18 AM
cummins_guy's Avatar
if it were me.
replace pistons, rings and bearings
(check and make sure your cylinders are not out of round)
put marine pistons in, I would also put marine cooling nozzles in.
The leak down test is an old trick, you could put the head back on and do a compression check to really be sure what it is.
if you need parts, you can give Brice at BBD Performance a call or send him a pm.
Good luck
Old Aug 27, 2010 | 07:28 PM
captain_stabbin's Avatar
whats the mileage on the motor?
Old Aug 27, 2010 | 07:36 PM
Can you elaborate? Why?
Old Aug 27, 2010 | 08:01 PM
big bad diesel 416's Avatar
Site Sponsor
those pistons are .20 shaved eliminating the need to run a .20 over "marine" gasket = lower compression = more air = lower EGTS = more room for more fuel = MORE POWER and the marine nozzles flow more oil to the pistons
Old Aug 28, 2010 | 09:28 AM
bigdan120's Avatar
Default Leak Down
155,000 to answer your question. Doesn't seem like many but it was a construction vehicle and i'm not sure if it was left idle a lot. I bought 2 off them in a KILLER DEAL 700.00 for both trucks. 1 has a locked up motor with 350 on the clock regular cab. The other I put lower control arms on it and drove it home. It is an 2500 95 extended cab. Both are 4X4 Auto 2500 cummins Turbos. The other is a 94. Rotted pretty bad. I did find a broken valve spring before I pulled the head. I fixed that and still had a miss. When I pulled the head and checked the valves the exhaust valves are pretty nasty looking with deposit's on them PITS under that. But nothing bent. So since I have it apart I am thinking about putting rings in it.
Old Aug 28, 2010 | 09:38 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
when we pull a head off here, we have it decked and always run a cummins .020 marine head gasket.
Old Sep 2, 2010 | 09:06 AM
bigdan120's Avatar
Ok update. Took it to my buddy all my valves where leaking. Redid the valves hopefully it will help alot.... We will See....LOL
Old Sep 2, 2010 | 12:04 PM
Site Sponsor
liquid test the head before you put it back on
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
ash23k
Dec 30, 2014 08:31 PM
Oct 31, 2014 08:10 AM
