can you lock the p7100 in position?
Old Aug 26, 2010 | 11:12 PM
jpfiero's Avatar
Default can you lock the p7100 in position?
I'm in the process of swaping all of the top end and fueling components from a '96 12v to a '93 block (the '96 developed some large holes).
I need to know if I can set the '96 engine at TDC and lock the pump in position so that it doesn't move when I transfer it over to the '93 block?
We where able to lock the pump on the '93 engine when we removed it but I can't find any info on locking the p7100. I've tried searching around but I can't seem to find anything, if you have links to where this has been discussed previously that would be great!
Thanks.
Old Aug 27, 2010 | 08:54 PM
cummins95's Avatar
chances are the timing has slipped over the years. you should prolly have the timing set right n might as well bump it while you are doin it
cumminspwr11
12
Oct 17, 2021 03:50 AM
CGwill
Apr 21, 2016 10:13 PM
robbyS
Apr 16, 2015 02:22 PM
Cody Cain
Dec 22, 2014 01:27 PM
Cody Cain
Dec 21, 2014 06:50 PM
