trans goerend valve body install do need to drop the trans
Old Aug 26, 2010 | 06:41 PM
MUSCLE1's Avatar
Default trans goerend valve body install do need to drop the trans
help is there more to it then just the valve body?
Old Aug 26, 2010 | 06:58 PM
IrishMan85's Avatar
Did you buy a whole new valve body or are you installing a shift kit with new electronics. Either way all you need to do is drop the transmission pan. Make sure you take your time taking out the C-Clip that holds the parking pawl, it's kind of a pain. A long pair of skinny needle nose pliars will be your best friend.
Old Aug 26, 2010 | 08:50 PM
cerberus60's Avatar
VB swap is easy, you just have to disconnect all the external conections and linkage and remove the bolts. Don't mess around with the park rod c-clip, jack up one rear wheel so you can pull the rod attached to the VB. Roll the wheel slowly while pulling the VB forward and the rod will pull thru the pawl easily when it lines up with the notch.
jeremiah1
Jul 21, 2015 06:35 PM
Bigredpowerstroke
Feb 3, 2015 05:48 PM
countryboy040993
22
Nov 12, 2014 11:25 AM
