What parts do I need to turbo a 6.2
Old Aug 26, 2010 | 05:48 PM
butcherman's Avatar
Default What parts do I need to turbo a 6.2
Hey, I found a wrecked truck that had a 6.5 turbo in it. The turbo is missing, but the exhaust manifold was still there, along with most of the engine. Besides the turbo, what else do I need? Would a holset from a first gen dodge bolt up to the 6.5 manifold? And I'm not sure how to run the oil lines...any ideas or advice?
Old Aug 27, 2010 | 12:11 PM
Livelli's Avatar
Install a 'T' at your oil pressure sending unit and run a line to the top of the turbo (oil inlet) and the drain should go down to the fuel pump block off plate (where the lift pump is on a 6.2). The holset could work, but not without HEAVY modification (intake and exhaust welding). You'll also need a way to control the wastegate. You could use the laggy unreliable vacuum setup on a usual GM-X, but most people opt for a Heath Turbomaster. I forgot to ask, are you setting THAT motor up to run again with a turbo, or putting a turbo on your K5 6.2?
Old Aug 27, 2010 | 05:37 PM
butcherman's Avatar
I don't plan on going to a 6.5. I was just going to use the parts from the 6.5 to turbo my 6.2. I wasn't even thinking about a wastegate. My first gen dodge didn't have one, so I thought I would see if I could do the same with the 6.2. Do I really need the wastegate?
Old Aug 27, 2010 | 11:53 PM
Livelli's Avatar
im using my phone so i dont have access to all my data, and what all parts you will need to turbo a 6.2. When i get back to the base ill fire up the laptop and get you better intel. You need the wastegate to control your boost. The 6.2 has very high compression and can only handle 10-12 psi MAX. An uncontrolled wastegate could also lead to dangerously high EGts, then melted pistons.
Nevermind, couldnt PM. Try this page, Brent has done his homework:
6.5 turbo parts on a 6.2 - Diesel Place
Old Aug 29, 2010 | 04:56 PM
rescueeskew354's Avatar
I happen to have a complete 6.5 engine with everything you will need to do this project with the exception of a few little parts like the T for you oil and stuff like that .If your interested let me know the engine is still in the truck I would be willing to work something out with you
Old Nov 10, 2010 | 02:04 PM
tripod808's Avatar
x2 for parts needed. I'm shopping around for a 6.2 blazer and want to turbo it.
Old May 29, 2016 | 10:21 PM
Whitemat's Avatar
Question
Hey so I have a turbo not sure what kind or anything yet havnt really looked at it but I want to put it on my 2005 GMC Sierra Denali 6.0 vortec what all am I going to need to install it? Thanks
Hollie
6.2L & 6.5L Performance
Jan 14, 2016 01:32 PM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
Whitereaper12v
Jan 28, 2015 11:01 AM
GreenDieselF
Oct 20, 2014 02:05 PM
