94 turbo on a 89
Old Aug 26, 2010 | 09:22 AM
fravelj's Avatar
ATTN 94 turbo on a 89
can you put a 1994 7.3l idi with turbo take the turbo and intake hat and put it on a 1989 7.3l idi? and if so how do u take the turbo off the 94 ?
Old Aug 26, 2010 | 09:59 AM
FordDZLMan9191's Avatar
It will fit, but I think you need more than just the turbo and intake hat. I can't help with how to take it off since I've never done it. Someone should chime in that knows what to do though.
Old Aug 26, 2010 | 10:15 AM
cowboyford16's Avatar
everything will bolt on. You need oil feed line to the turbo, and a blow by canister. So you have to have the driver side valve cover. And for the turbo you just un bolt the Y pipe the down pipe the pedistal for the Up pipes and diconnet your heat shield and oil feed line and your ready to put it all on.
Old Aug 26, 2010 | 12:11 PM
DieselCrawler's Avatar
yea, u need up pipes, down pipe, oil return line, oil feed line, snail shell intake, turbo, driveisde valve cover, and air cleaner assy. bolts on pretty easy. took me about 5 hrs total doing it myself.
i have a 94 turbo on my 86.
Old Aug 26, 2010 | 01:43 PM
fravelj's Avatar
thanks everyone yall really helped me out what all do i need of the 94 ? like manifold value cover exc
Old Aug 26, 2010 | 02:33 PM
i listed everything u need in my prevoius post.
Old Aug 26, 2010 | 03:03 PM
fravelj's Avatar
do i need the manifolds?
hows urs run since u put it on there? and does it blow smoke?
Old Aug 26, 2010 | 03:56 PM
no, the uppipe bolts to the original manifolds.
mine runs good. only a haze of smoke when stomping on it.
Old Aug 26, 2010 | 04:03 PM
fravelj's Avatar
was it easy to get everything off the 94? and where does the uppipes bolt to the manifold at?
can u tell the difference? and can u hear the turbo like at the exhaust pipe?
Old Aug 26, 2010 | 05:56 PM
i hear my turbo loud. whistles pretty good.
yes i can tell difference. mine is a play toy, so not to much road travel. but in the mud it spins second high prey good now with my 3.54 gears and 36's.
spray up all the exhaust bolts with pb before removing, other than that it comes out pretty easy. hard part is reinstalling. fun to line everything up yourself.
