Hesitation or Miss "HELP"
Old Aug 25, 2010 | 08:09 PM
warenemout's Avatar
Default Hesitation or Miss "HELP"
I have a 96 Burb, stock with relocated PMD and Turbo Master. If this truck was a gas burner i would think it had a fould plug. Running at highway speed 60 -70 it will act like a missfire type of condition but not evertime i drive it . i have no current codes in computer.Will my lift pump act like this if it is going bad. This is my first diesel. Please Help.........
Old Aug 25, 2010 | 08:31 PM
War Machine's Avatar
my dad's 95 6.5 does the same, and its a scary combination of things that were wrong with his that made it do that... including a broken radiator, blown head gasket and a cracked block just to name a few....
The first thing I would do is make sure that your injectors are clean, get some cleaner from your local NAPA or whatever and see if that helps out, if you notice its helping then its more than likely an injector issure...
after that, make sure that there isnt any water in the oil or visaversa
Old Aug 25, 2010 | 08:42 PM
rescueeskew354's Avatar
Well it is not a plug . where did you get the pmd if you got it from SS diesel supply you wasted your money . Lift pump maybe . Is the truck running hot or does the temp gauge rise up and down is it hard to start
Old Aug 25, 2010 | 08:56 PM
warenemout's Avatar
No temp related issues and i have a used pmd but i am running on the oe injectors at 151,000. Well overdue i know. could be prob? Which injecters would you recamend?
Zach56238
Sep 3, 2015 06:57 AM
02Stain
Mar 18, 2015 10:40 AM
moneypitk5
Feb 12, 2015 11:01 AM
Power Ram Man
Feb 10, 2015 07:05 PM
7.3_powerhouse
9
Jan 17, 2015 02:22 PM
