replacing injectors
Old Aug 24, 2010 | 08:42 PM
zach_west's Avatar
Default replacing injectors
i'm supposed to help replace the number 5 injector in my friends 04 6.0 and need to know how to do this. I'm a dodge guy so i'm not sure. also need to know where the egr valve is so i can clean it, i told him to delete it but he won't listen to me haha. any help would be appreciated
Old Aug 24, 2010 | 09:02 PM
Mdub707's Avatar
EGR valve is right on the top of the motor when looking straight down, kind of behind the intake elbow. Here's a pic looking from the rear of the intake manifold forward.
Here's a good write up to cleaning it... Diesel Technician Society
#5 injector is on the passenger side. They're pretty straightforward once you dive in there... Are you using a new or a used injector? If used, make sure to use a new o-ring. I've also heard of them coming loose after reinstallation and causing a rough running condition. May want to torque just a hair more than what it calls for.
Old Aug 24, 2010 | 10:16 PM
zach_west's Avatar
well his is just not wanting to start . and i thought the number 5 was on the passenger side? idk i'm not a ford guy haha. do i have to reset valves?
Old Aug 25, 2010 | 12:40 AM
Mdub707's Avatar
6.0L Bible Table of Contents
Scroll down, there's info on injector removal.
You are right, #5 is passenger side, brain fart. That is the harder side unfortunately.
The cylinders of the 6.0L Power Stroke are numbered from the front on the right side 1, 3, 5, 7 and from the front on the left side 2, 4, 6, 8
I've seen these trucks run on 7 cylinders no problem before, so are you sure it's the injector causing the no start, or is that just part of the problems? Is it throwing any codes? I'm assuming codes were read and this is how you figured out #5? I would maybe test the FICM too. ICP could also cause a no-start issue. How many miles on this truck? Any mods? Was it smoking at all before this happened? Did it die suddenly, or did he shut it off and now it just wont start?
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
