diffrent setup... turbo question
Old Aug 24, 2010 | 06:53 PM
kyle davis's Avatar
Default diffrent setup... turbo question
i can get my hands on an ht60 turbo im not sure i can power it i have an edge and 100hp injectors can i use it with my hx35 turbo for a good set of towing twins?
Old Aug 24, 2010 | 07:32 PM
Farmboy 2.0's Avatar
ht or is it an hx60? Thats way to big i think to run as a single turbo. It would take way bigger injectors and a cam to get that to light before next year. It would make a decent twin setup with a stock charger on the top.
Old Aug 24, 2010 | 07:36 PM
kyle davis's Avatar
its an ht off like a late 90 cummins n14 i believe and i dont wanna do a single i would like twins, thats why i was curious if it would work with my setup
Old Aug 24, 2010 | 08:14 PM
RAW's Avatar
RAW
It will work as a primary in a set of COMPOUNDS. AS it is not another HX35 it will not be a twin set up.
Old Aug 24, 2010 | 08:36 PM
kyle davis's Avatar
thats what i meant hx35 and the ht60 as compounds... but will i have enough fuel? thats my concerne
Old Aug 24, 2010 | 08:57 PM
Sorry i meant compounds I have a tendency to use the word twins loosly when it comes to diesels
Old Sep 3, 2010 | 06:47 PM
kyle davis's Avatar
also while working on getting them in i nicked a fin on the compressor wheel a bit and now im worried it wont work any idea? only like the tip maybe an 1/8 or 1/16th
Old Sep 3, 2010 | 08:15 PM
turbo20psi's Avatar
You can lightly sand the nick down.Clean the wheel as you are sanding it.Taking the turbo apart would be the best,if you are careful this can be done together.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
torg73
May 11, 2015 03:08 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
