How do you reset the apps sensor?
Old Aug 24, 2010 | 06:39 PM
blowin smoke 1's Avatar
Default How do you reset the apps sensor?
I installed a new apps sensor do I need to do anything else?It runs ok if I dont get on it real hard but its not like used to be.Could my vp be getting weak it has 240000 miles on it.Dang money pit!
Old Aug 24, 2010 | 07:37 PM
Farmboy 2.0's Avatar
Here ya go
APPS Reset Procedure
This procedure has shown to help 24 valve ISB engines. It is basically teaching the fly by wire accelerator on these trucks to reread the position of the pedal and it's limits. Most complaints this will help with is poor acceleration, improper shifting, bucking in 5 and 6 speeds. Has been known to increase fuel mileage in some instances.
1. Set parking brake
2. Disconnect negative battery cables on both batteries
3. Turn ignition key to run(to drain any remaining capacitors)
4. Let truck sit for 30 minutes( this is the recommended minimum)
5. Return ignition to OFF position
6. Reconnect both batteries and secure, not a timed event
7. Turn key to run position(not start) and depress accelerator pedal slowly all the way to the floor
8. Allow pedal to return to top position slowly
9. Turn ignition switch OFF
10.Release parking brake
Old Aug 24, 2010 | 08:19 PM
RAW's Avatar
RAW
Yep, that will do it!
If you have the EJWA, place throttle position in one of your display items. See what happens with pedal travel.
Old Aug 26, 2010 | 09:01 PM
I did that today it still will only build 18 pounds of boost on stock setting.It runs ok in #6 but takes forever to build boost checked boots,map sensor.Maybe its the pump?
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Mr. Walkway
May 11, 2015 10:49 AM
robbyS
Apr 16, 2015 02:22 PM
Gitana
Feb 18, 2015 10:08 AM
