clearance question
Old Aug 24, 2010 | 03:36 PM
dodgethat's Avatar
Question clearance question
I have a 06 2500 can I mount 35-12.50-17 on stock rims and not have trouble with them on the my truck will it rub front of front or back of front or is it ok just not the best
Old Aug 24, 2010 | 04:17 PM
NadirPoint's Avatar
No, you're going to need at least 2" lift and 1/2" longer control arms would be a good idea too. The tires on my 07 measure 34.8 according to the manufacturer and with 2" lift still have a minor rub on the back fender corner on turning compression.
Old Aug 24, 2010 | 05:22 PM
crzycummins's Avatar
x2
Old Aug 24, 2010 | 07:44 PM
CHEMMINS's Avatar
x3
It doesn't bother me though. It is only on real tight slow turns I notice it.
Old Aug 24, 2010 | 07:50 PM
Originally Posted by CHEMMINS
x3
you mean the ones at the gas station pulling into a spot and it rubs and everybody looks at you like wtf is wrong with that truck??? ha
Old Aug 24, 2010 | 08:54 PM
Ick06's Avatar
yes u can fit 35/12.50 on stock wheels with minimal rub like when hard down i ran 35 on mine for a year without trouble
Old Aug 24, 2010 | 09:34 PM
dodgethat's Avatar
thanks guys I mite just buy a 2 inch lift for the front and back nice to know they will fit with little trouble thanks Ick06 and the rest of the guys
Old Aug 25, 2010 | 01:12 PM
sinwagon's Avatar
you can just put a 2" leveling kit in and get the same clearance without the extra expence of a full lift
Old Aug 25, 2010 | 01:53 PM
NadirPoint's Avatar
Let me make just a minor spelling correction for you:
Originally Posted by sinwagon
you can just put a death wobble starter kit in and get the same clearance without the extra expence of a full lift
I have the spring spacers in mine, don't get me wrong. But you are headed for problems if you run those without the necessary supporting mods including the bare minimum of an adjustable or lengthened trackbar or a drop bracket for the stocker.
Old Aug 25, 2010 | 02:37 PM
CHEMMINS's Avatar
Yeah the spacer kits do give a bit of wobble. I don't find it that bad on mine, but everything on mine is tight....for now. Mine only happens around 45 mph.
