Turbo removal?
Old Aug 23, 2010 | 10:24 PM
Snowman's Avatar
MR.3K
Default Turbo removal?
Just woindering how hard it is to remove the turbo on an 03 6.0L in an F-350 crew cab?? What all has to be removed? or do i have to lift the bloody cab??
Old Aug 24, 2010 | 07:22 AM
HeavyAssault's Avatar
Remove the intake assembly, disconnect all the stuff connected to the turbo, remove turbo. 2 hours max.
Old Aug 24, 2010 | 11:31 AM
Mdub707's Avatar
Yeah not bad at all. Just make sure you have a good combination of ratchet extensions and a swivel joint. Not too terrible. A nice comfy blanket to put on top of the motor so you can lay on it never hurts either!
Old Aug 24, 2010 | 12:14 PM
Snowman's Avatar
MR.3K
ok thanks alot guys! I'll get that done tonight then, sweet.
Old Feb 21, 2012 | 09:40 PM
GeArHeArT's Avatar
How the hell do you remove the oil return line on an 03?
Old Feb 21, 2012 | 10:31 PM
bobfbigman's Avatar
You have to remove the turbo to get it out, it just pushes in, you can lift it up and pull the tube out and just put the updated one in if that is what you are trying to do.
Old Feb 21, 2012 | 11:17 PM
GeArHeArT's Avatar
Doing a bunch of stuff. Last mechanic to have the turbo off rounded off all the heads on the bolts to the turbo mounts on the pedestal. So kinda fighting that right now.
Old Feb 22, 2012 | 11:17 AM
Powerstroking814's Avatar
There is a good video on YouTube for the rounded bolts
Old Feb 22, 2012 | 02:43 PM
drdiesel's Avatar
Yeah the 03 early 04's are a little harder to remove than the later models. Oil supply line can be removed from top of turbo & pushed aside, unless you need to replace it, the black collar slides down & unlocks the lock ring to pull out. As for the bolts get a pretty new 6 point socket 3/8 drive & breaker bar, works most of time. If someone rounded off the heads you'll need a set of turbo sockets. In worst case scenarios I've had to use a Right angle die grinder to cut thru at least the rear bolt spacer then pry the turbo out once other 2 bolts are out!!!! Good luck
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
